Slim Centre Speaker Required - Advice Sought
Discussion in 'Home Cinema Speakers' started by windfall, Jan 27, 2005.
  1. windfall
    windfall
    Oct 19, 2003
    2,409
    48
    LFC Kop End
    +61
    Hi Chaps
    I am taking a trip over to the states in a couple of weeks and my brother in law has asked me to get him a centre speaker.
    He wants one that can sit under a plasma and not look out of place.
    So he is looking for a rectangular box 4" deep (100mm) by 12" wide (300mm) and prefer something in silver.
    The worst bit is that he doesnt want to spend an awful lot (£50) so I think we are looking for a budget speaker.
    Can anyone point me to a retailer that may be able to help. Have looked on richer Sounds but nout there.
    Tone
  2. Astaroth
    Astaroth
    Suspended
    Jun 22, 2004
    3,653
    2
    London
    +882
    You may want to consider the Mission M3c1 - it is a little smaller in depth than you ask and doesnt look bad under a plasma screen - superfi are currently listing it at £69 and so it isnt a million miles from your budget and a little shopping arround may get it cheaper
  3. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Yamaha have a new range of speakers, and the centre is extraordinbarly thin. Is certainly worth a look, i had a sub sat (model 220) yamaha and they wern't bad.
  4. windfall
    windfall
    Oct 19, 2003
    2,409
    48
    LFC Kop End
    +61
    Thanks chaps - some good advice - will take a look!
    Tone
