slightly jerky picture?
garyc
Does anyone have any thoughts on why the video play back when playing from the hard drive is a little jerky?
pc spec. 3.0ghz, 1gib of ram, x550 256mb graphics card
playing an avi file you get a slight jerkiness on slow panning
video is playback via a crt projector
cheers
Gary
D
Deleted member 39241
Sounds like it could be refresh rate judder, try adjusting from 50hz to 60hz or vice versa.
garyc
I'll have a look
just to add, my using theatertek with processing via ffdshow.
The avi's are 23 frames, any other settings that may effect this issue
cheers
Gary
ChrisOH
As Lisa says this is probably refresh rate. Have a look at the read me file that comes with the Reclock download. It gives a good explanation of what is going on. Essentially, PAL = 25 frames per secon, NTSC = 30 etc and the refresh rate needs to be a multiple of this. ie PAL, 50, 75 or 100Hz, NTSC 60Hz etc
Chris
