Slight Problems With Freeview
Discussion in 'Freeview & YouView' started by Boopop, Jul 4, 2005.
  1. Boopop
    Boopop
    Jul 4, 2005
    25
    I'm currently trying to get my Freeview box in my bedroom to connect to my tv and my pc tv card. But for some reason there are odd slight horizontal lines goin up the the screen while the Scart cable works fine. I would connect this to my tv card but it doesn't take scart. Here's my setup [​IMG]
    [​IMG] As well as expectable pixelation ( or whatever you call it) zooming in on this screenshot will show you what I mean. The Freeview box is a Pioneer TBR - T210GBS.
    Thanks in advance, Tom
  2. HarryAlffa
    HarryAlffa
    Jan 6, 2005
    61
    Is the screenshot from your TV or from your PC?
    Do you get the same problem on your TV and PC?
  3. HarryAlffa
    HarryAlffa
    Jan 6, 2005
    61
    So what you're saying is that you are getting a degraded picture on the ariel signal, but from the same source the scart signal is perfect?
    If this is the case then it sounds like (and looks like from your screenshot) you have two RF signals which are to close together. If, for example, your Sky box was sending it's signal over the ariel cable on RF 21 and your freeview box was sending it's signal over the ariel on RF 22 (or even RF 23) then these two signals will interfere with each other.
    Where you can choose the RF channel a piece of equipment sends it's signal on, then make sure that it is plus or minus 2 channels from it's nearest neighbour, and sometimes plus or minus 3.
    Hope this helps.
  4. Boopop
    Boopop
    Jul 4, 2005
    25
    Thanks, I'll try that when i get home, I'm at school at the moment :D
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Get on with your lessons ! :D
  6. Boopop
    Boopop
    Jul 4, 2005
    25
    At home now :D How do I change the RF Number?
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I think it's in the engineer's menu - Services, 4, 0, 1, Select.
