slight problem with fujitsu 42" plasma
Discussion in 'Plasma TVs Forum' started by matt bellamy, Nov 9, 2004.
  1. matt bellamy
    matt bellamy
    Jun 19, 2004
    230
    16
    hi,
    I was wondering if anyone knew of a solution to a problem that I have with my plasma. The problem is with the aspect ratio. The screen sometimes can't "decide" on which aspect ratio to set to and on some DVD's/games it will continually flick between different aspect ratios. There isn't a way on the menu to set the screen ratio but was wondering if anyone knows of a way to solve the problem.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    This is a VHA or HHA on scart, we are guessing. Sounds like a problem with the source. I'd be willing to bet the console does not send any aspect data. I think I'd be inclined to clip pin 8 off the scart lead, and use the remote to set it manually.
  3. matt bellamy
    matt bellamy
    Jun 19, 2004
    230
    16
    No it's not connected with a scart. The games consoles are connected to a yamaha amp with video leads and the dvd played is connected to the yamaha amp with an s-video lead. The yamaha amp is connected to the tv with an s-video lead. I have tried connecting DVD player directly to the tv with s-video lead but get the same problem.
