slight niggle with my yammy rx-v630rds
Discussion in 'AV Receivers & Amplifiers' started by james.miller, Apr 12, 2003.
  1. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    the pre outs (sub,L,R ect) are all very low. im sure they shouldn't be that low. I used to have a yamaha processor and the sub output from that was 10 times what it is from my amp. i literally have to turn the sub amp to full to get a decent responce from it (which as you can imagine brings some nasty background noise into the equation when it shouldn't). It's also the same from the 6-channel out aswell.
    Is this normal? or is there something i can do about it?
    btw i have main speaker lever set to -10 and LF level set from -2 to -0 on the yamaha
  2. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    oh and, while i think about it - is it ok to leave the impedance selector at 8omhs when im using 4-8ohm speakers?
  3. SystemBlack
    SystemBlack
    Not sure about the 630 but my AX620 seems to be ok, have it checked out to see if everything is hunky dorey and if you use one set of 8 ohm speakers, set it to 8 ohm. If you have any doubt, set the switch to 4 ohm, it will work ok and be safer for your amp.
