Slight Distortion in left back speaker (denon 550)
Discussion in 'Home Cinema Buying & Building' started by spookster, Feb 27, 2005.
  1. spookster
    spookster
    Jan 15, 2005
    1,412
    Epping
    +154
    Hi All,
    Please be gentle. Not technically brilliant when it comes to hi-fi set ups etc - and I still need to work on one or two things with my Denon 550 setup.
    However, currently I can hear slight distortion on the left surround speaker.
    I'm watching 24 - and when it goes to an ad break, you can clearly hear a little distortion coming out of that one speaker.
    I need some general advise here, and I also need to know what I have to setup up within the setup menu (for example, what do i set the db's too? for each speaker)?
    can anyone help?
    cheers
  2. Smiffy 2
    Smiffy 2
    Nov 20, 2004
    1,921
    2
    Bexhill on Sea
    +302
    I get exactly the same problem when I first fire my system up. It sorts itself out after a minute or two but it is still mildly concerning.
    It only seems to be on one output setting, and at the moment I can't remember which one it is!!
    Rob
  3. spookster
    spookster
    Jan 15, 2005
    1,412
    Epping
    +154
    the distortion always appears to be there, though sometimes its not noticeable.
    maybe its when the sound out of that speaker reaches a certain level or tone (or whatever).
  4. spookster
    spookster
    Jan 15, 2005
    1,412
    Epping
    +154
    I'm gonna swap the left surround speaker with the right one and see if i still hear the distorted sound coming from the left hand side.
    if i do, then will the problem be down to the speaker wires or the amp itself?
    if its the amp, i'm gonna be very very upset.
    of course, if the distorted sound comes out of the right hand side - that would mean its the speaker itself.
  5. spookster
    spookster
    Jan 15, 2005
    1,412
    Epping
    +154
    swapped the speakers round, so the left one is now sitting on the right hand side.
    still getting that distorted sound.
    fantastic.
  6. Smiffy 2
    Smiffy 2
    Nov 20, 2004
    1,921
    2
    Bexhill on Sea
    +302
    Spookster
    are you getting this garbled sound on ALL output settings (obviously not the stereo one!!).
    The only reason I ask is that I seem to remember a thread a few weeks ago that also mentioned this and bearing in mind I also get the problem it could be a "feature" (although unrequired) of the system.
    I cannot for the life of me remember which setting I have mine on when I get it, but I know it's certainly not there when I just leave the system to play DTS encoded discs or the more "usual" output settings.
    It is literaly this one output setting that causes it.
    I hope this makes sense (cos I'm a numpty where these things are concerned),
    Rob
    Missed your other question in your first post regarding db settings by the way. I, like most others with this system have set mine to +10 for all of the speakers EXCEPT the sub which is set at +5.
    This enables me to listen to the system comfortably without venturing near the 45 volume setting which will set the cooling fan whirring whilst watching DVD's. Not that this "whirring" is too annoying, but you just know it's there when you come to a quiet passage during playback.
    Hope this helps, and don't give up on the 500 just yet. It really is a great system!!
  7. spookster
    spookster
    Jan 15, 2005
    1,412
    Epping
    +154
    i think it might take a little while for me to work out what sound options i need selected depending on what i am watching.
    any advice here?
    if i'm watching Sky One or Sky Sports or any other channel - should I simply have the Dolby option selected?
  8. pakeen
    pakeen
    Mar 21, 2005
    124
    16
    Peterborough
    Sorry to intrude but I am an absolute newbie who just wants to transfer old audio tapes to CD & haven't a clue where to start. I have a PC with Cd burner, PACE Twin,standalone DVD burner,& VCR. If someone could just point me in the right direction I would be most grateful & get out of your way.Thanks&Sorry.
  9. Conn
    Conn
    Jan 2, 2005
    2,075
    +170
  10. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    I have found that the slight 'garbled' sound that eminates from the rear speakers is caused by the ProLogic system in the Amp trying to produce the rear effects from poor quality Stereo sources. Some Stereo sources are more suitable than others when it comes to ProLogic processing. Try flicking the setting onto Neo6. This surround option is really for a 6.1 system, but really works quite nicely as an alternative to ProLogic - more 'spacial'...
    Jimmy
  11. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    I contacted Denon about this, they said it was due to a bad analogue source being fed through (even though I am listening either via optical for Sky+ or by the Denon for dvds). I think it is just part of the system.
    I get a noise coming out of the back speakers when someone is speaking, the noise matches the length of the speech but is unclear but only on certain tv programmes. Some are perfectly okay so I think it is something to do with the source material.
  12. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    What Denon are saying is that the origional Analogue source is poor - it's nothing to do with your connections or your System - see my previous post.
    Jimmy
