Slight 11ht Problem
Discussion in 'Projectors, Screens & Video Processors' started by leon, Dec 30, 2001.
  1. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    hello i have set up the 11ht but i have noticed a slight problem on the bottom left of my picture (7ft da-lite screen ) it seems to slope downwards ,the projector and screen were set up using lasers and the screen is in perfect 16/9 (measured it )when you follow the bottom line it slopes down about 10 mm from the centre ive tried keystone and differant formats through the projector but it almost like the lcd panel is not level along the bottom ???
    any ideas ill phone up marata and see if they no tommorow .
  2. Metric
    Metric
    my 10 wasnt perfect, i had to overspill a little to get all corners covered
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,266
    UK.
    +2,787
    I've a Davis DLS8, and I noticed a similar problem with mine.
    It turned out the pj wasn't perfectly centered on the screen, so to be lined up, I had it slightly twisted to the right (without realising).
    I moved the pj about an inch to the right, realigned it, and now both bottom and top are level.
    I think that because the pj has a fixed amount of keystoning built in, when it's off center, (and depending on whether ceiling or table mounted), the top stays straight, but the bottom will show any out of skew adjustment.
    HTH
    Gary.
