sliding living room doors?
Discussion in 'Home Cinema Building DIY' started by Neil.B, Jan 7, 2012.
  1. Neil.B
    Neil.B
    Jan 22, 2006
    707
    Hornchurch/Essex
    +24
    Has anyone made a false wall with sliding doors?
    I want to put back the living/dining room back to seperate rooms.
    instead of hinged doors i want to have sliding doors. The doors will be normal doors.
    What would be the best sliding runners to use?
    Neil
  2. jonna
    jonna
    Mar 25, 2002
    3,188
    Cheshire
    +2,469
  3. skaterstan
    skaterstan
    Jan 9, 2005
    111
    United Kingdom
    +8
  4. marinemitch
    marinemitch
    Oct 22, 2007
    64
    When you mean sliding doors do you mean recessed or on the wall face?
    A house i am working in at the moment has an internally sliding door fitted to a small wc, the client could not fit a commercially avalable kit as they have used solid oak ledge and brace doors throughout.
    the door runs on a rail
    Straight Sliding 900-1150mm 55kg, SDS Ball Race 55 & 90Kg, Architectural Ironmongery, SDS London
    the same as what is used for sliding wardrobe doors but built within the stud wall.
  5. Neil.B
    Neil.B
    Jan 22, 2006
    707
    Hornchurch/Essex
    +24
    Thanks, this is what i was thinking of.
    The other suggestions were correct too but way out of my price range.
    Neil
