Slick-design floorstanding speakers
Discussion in 'Home Cinema Speakers' started by calvinhobbes, Sep 8, 2004.
  1. calvinhobbes
    calvinhobbes
    Hi all
    I have just bought a Celestion AVP305 5.1 system but am looking to upgrade the front speakers to a pair of nice floorstanding speakers that go with the nice design of the Celestions (e.g. metal finish not wood, slick not too massive).
    Any recommendations? Would like to stick under £300.
  2. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Canton Karat series...
    Kef Q series in Silver finish...
  3. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Celestion AVP302 in glass?
  4. KHCC
    KHCC
    Aug 10, 2004
    256
    Kent
    +10
    Mornin'
    The only problem with the Karat floorstanders is that they cost £900 and the budget is £300.
    If you wanted to push your limit, you might consider the Canton CD100 floorstanders, they are very sleek and silver have a look on our AV-SALES website. If you are localish you could come for a demo.
  5. meinbrain
    meinbrain
    mordaunt short 914 or 906?
  6. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Tehy are very expensive, I was thinking of buying them in German Net shops, but even then floorstander models are still expensive...
    Look for a Kef Q4, available in silver... or Q1 or Qcompact bookshelf models.
  7. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Vienna Acoustics make some nice speakers slick design but again are £1000 per pair. Second hand maybe?
    www.vienna-acoustics.com
  8. calvinhobbes
    calvinhobbes
    Will check out the Cantons, MS, and Kefs. The others are a bit too expensive.
    I can't find anywhere that does the Celestion AVP305s in glass.
  9. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    The Celestion AVP305s in glass have just been launched I believe, so it may take a little time for them to hit the retailers.
