Sleepy Barco Data 801S
Discussion in 'Projectors, Screens & Video Processors' started by j19hnd, May 29, 2004.
  1. j19hnd
    j19hnd
    My 801 has been reliable for 2-3 years, however recently I have been having a problem after the projector has been running for about 40 minutes.
    After that time the screen goes blank and the projector powers down and will not restart. Switching off the power for half an hour allows it to restart.
    When the projector shuts down all the yellow led's next to the G2 / Focus block go out and the row of red led's are as follows:-
    Error - on Block Match - on Process Cycles - flickers Stdby Power - on
    has anyone experienced a similar problem or have any idea what could be wrong.
    thanks
    John
  2. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    j19hnd:
    Sorry to hear about the problems with your PJ, maybe someone like Roland or one of the wizards can help you out ??
    Have you tried to reseat all the cards, they can work themselves loose over time , especially when using a big subwoofer.
    I'm still a newbie when it come to CRT PJ's, but i'm learning all the time !! :smashin:
    Cosmic023
  3. j19hnd
    j19hnd
    thank`s Cosmic023 for your thoughts i wil try reseat all the cards but i am still waitting for Roland or one of the wizards to reply
  4. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,211
    3
    +8,314
    I get the same problem most nights i use my Barco 800, it doesn't shut down completely the power starts pulsing as if it is trying to restart again. I leave it for about 20mins then press the power button and it comes back on and stays on for the rest of the night. Strange.
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    John I think you are experiencing a scan fail shut down. If it was an EHT problem the projector usually keeps running but no picture.
    You may have a dry joint on the Vertical or horzontal board., go over these with a soldering iron if you feel up to it.
    It could also be the power supply giving up again these suffered from dry solder joints.
    Reseating the cards my help if they have not been touched for a few years.
    Untill this becomes a reproducable failure its nearly impossibel to help I'm afraid.
  6. j19hnd
    j19hnd
    thanks guys i will try all your fixes and see if they help . the advice is much appreciated
  7. bpasco
    bpasco
    Jan 12, 2004
    Washington, DC
    I'm curious what the solution to your problem was. I have the exact same issue, with the same symptoms and indicators, on my 808s. Any insight you can provide is greatly appreciated.
  8. j19hnd
    j19hnd
    Hi I have fixed my problem with a very good and proven solution that fixes most TV and other electrical things when you open the case there is a large metal plate on the left hand side near the diodes hit it very hard with your hand a right good thump and it kicks back into live sometimes it can be fixed for months or just a short time but do the same again and it should work .hehehehehe .
    I must have a dry connection I have tried all the boards but cant see anything wrong, but the bit that I hit is right at the power input so I may have a bad power pack. I just hit it through frustration and it worked so have some fun venting your frustration out at the Pj . Good luck
  9. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    John
    Exclent solution :thumbsup:
    Here's the rest of us wondering if resistor 141 should be 10k or 10.000001k. or perhaps the mains input voltage should be 230v rather the 229.7v.
    "No mate just give a good thump, show it who's boss"
  10. j19hnd
    j19hnd
    thanks for the support Roland but do you have any of these parts cheap. I can`t source the following second hand parts cheap how much would you charge me .
    1. for Barco 701 - convergence board 762454 780319-1 0594
    2. for Barco 701s - input board R762228 780352-1 4595
    thanks
    John
