slayers without ftp
Discussion in 'Nintendo Forums' started by mitch, Jan 6, 2004.
  1. mitch
    mitch
    Sep 6, 2003
    4,702
    +431
    i like the idea of putting evox on my special xbox.i have an xecuter 2.3 fitted with cromwell bios.how easy is it to install slayers evox.i have read that i need to ftp info between the xbox and pc but as i dont have a network card this isnt possible.would i need to change the bios first or could i just put in slayers auto installer and let it run.i am very much a newbie and am quite scared of stuffing up my xbox.any advice would be greatly apreciated.
  2. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    If you are happy to run the risk of data loss, then you can skip the ftp part, but don't blame me if it goes wrong :) I only needed the ftp'd files because I did a HD upgrade at the same time as the bios upgrade/evo-x install, and needed to transfer game-saves back to the new disc.
    However I couldn't get the slayer disc to update my cromwell BIOS, I had to make a seperate cd with just the bios on and use that first. Once that was done the slayer disc worked fine.
  3. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +644
    The new 2.5 disc looks pretty cool.
    You don't need to ftp into your xbox.
    Install a new drive put the disc in and let it do the rest. It comes with Linux too now.
  4. CMcK
    CMcK
    Mar 18, 2003
    391
    Scotland
    +28
    I used the Slayers 2.5 disc at the weekend to setup my Xbox with a 120Gb HDD. It's a doodle.
    I did use the FTP facility to backup my saved games but if that's not an issue go for it.
    This is one of the best things you can do with a Xbox. I've installed all of my games but 3 or 4 didn't work. No faffing around with discs and the loading times are vastly improved.
  5. mitch
    mitch
    Sep 6, 2003
    4,702
    +431
    thanks for the help guys.used slayers 2.5 and it was easy.i didnt even need to change the bios
  6. supersonic87
    supersonic87
    Dec 31, 2003
    286
    Swansea, Wales
    CMcK,
    If the games don't work with the hard drive, for the most, you can patch them (most fit on a cd, however you may need to use a dvd-r/w or dvd+r/w), which allow them to be used with a larger hard drive (mostly MS games)
    Rich
