Slanted top inch on Toshiba Direct view
Discussion in 'TVs' started by nathan_silly, Jan 25, 2003.
  1. nathan_silly
    nathan_silly
    Brothers got a Toshiba 28" Widescreen Pro-Logic TV, and the image looks like this... with a straight line, the top inch or so is slanted to the right.
    Will any of the service menu adjustments fix this?
    Also the red is way too high (ie, when comparing Toy Story red bit against my Panasonic TV, I can tell it's too high) Is the RCUT setting the correct one to reduce the red?
    Nathan
