Skyworth power wiring
Discussion in 'Blu-ray & DVD Players & Recorders' started by Soabirw, Feb 23, 2003.
  1. Soabirw
    Soabirw
    I just recieved a Skyworth 1050P and it is time to rewire the power cable to the standard U.S. plug. I've done a lot of electronics before so I am fairly confident I can pull this simple job off just fine, but since I don't know anything about how the Skyworth is setup since it complys to such a large range of power input I was curious if anybody out there as re-wired their Skyworth plug and can give me a quick walkthrough.
  2. Soabirw
    Soabirw
    Oops, I actually got the 1050D. Although it probably doesn't matter.
  3. Lare
    Lare
    Okay probably don't help you anything, but I received my 1050D just few days back and rewired the socket by just 1st unscrewing the Brittish(?) standard one, and then screwing a standard Finnish socket on.
    So no cutting or soldering is required, however I'm not familiar with the US wiring so I donno if this helps you any :)
