Skytec SPL1500 any good for a Buttkicker LFE?
simonlpearce
Am looking at wiring up a tactile transducer when I re-do my living room and have more or less decided on the Buttkicker.
Correct me if I'm wrong but there is no real need for a top of the range amp just to power this? So can anyone tell me if the Skytec SPL1500 will suffice, below are the specs...
2 x 750W output power
USB port / SD slot-in
FM Tuner (Radio)
Blue LED illuminated frontpanel
4 Selectable stereo inputs
Tech Specs
Power 230Vac / 50Hz
Output power 4 Ohms 2 x 750W
Frequency response 20Hz - 20kHz
Input 775mV
THD <0.5%
Signal to noise ratio >95dB
Crosstalk >82dB - 1kHz
Impedance >4 Ohm
Input impedance 10K Ohm min
Dimensions 482 x 270 x 88mm (19" x 2U)
Weight 5.1 kg
Thanks.
