sparkymarky
Established Member
Well after about three weeks of random freezes and turning itself off i called sky to get a replacement box for my Thomson Hd box.
Sorry to be non-pc but spoke to dsome foreigner as usual.
I explained it has random freezes and random power offs and only way you can turn it on again is disconnect from mains.
Made me go through the usual 'turn box off, disconnect lnb feeds, turn off at mains turn on again' then said is picture still frozen.
er no i said but i told you at the start it wasn't frozen at the exact time i called. 'Well it must have fixed it mr ....'
No, it does it randomly, i persisted and all your 'procedure' has done is turn it off and reconnect to the lnbs. He couldnt see it insisting we'd done some special procedure. Well then i insisted on an engineer so after 30 mins to an 0844 number which will prob cost a fortune an engineer will be out next thursday,
it amazes me how they just go through their screen and think they've done something magical i said to him just look at what we've actually done, ignore all the press services press system settings etc we haven't done anything!!!
