Skys HD service??
Discussion in 'Sky Digital TV Forum' started by ArcticFox77, Oct 4, 2005.
  1. ArcticFox77
    ArcticFox77
    Aug 8, 2005
    82
    Scotland
    I've heard from someone who works in Sky that the only way to get Sky's HD service is through a Sky+ box. Is this correct??
    Apparently according to him that's the only flaw in the HD service :confused:
  2. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    I believe you will need a new box,although if it is as cr*p as sky+ now don't know if i can take it!!!!!
  3. SeanT
    SeanT
    Jan 28, 2005
    6,125
    Coventry
    +371
    If they don't stop telling their employees that they are gonna get stitched up by trading standards.
    Sky HD will require a completely new, HD compatible, Sky HD box, which will function in a similar way to a Sky+ box, presumably have a bigger HDD and a DVI/HDMI output, component outputs aswell as SD outputs. It will not work on anything else, including a Sky+ or Sky+ 160 box (have heard that someone one here was sold the 160 box as it is "HD compatible" :mad: )
    There are pictures of the proposed new box on here (yes it is black)
