Skyplus V2 updated this morning(new update)
X
xyznicko
My Skyplus has been updated this morning to a new model number of 2.057A2.
Just checked Sky sports news and the Picture focus problem seems to have been fixed, can you check your PQ i'm not sure?
The other new features havn't been added yet.
STOWITBELOW
Im a little slow sometimes (this being one) is this a latest hardware upgrade - a new box, or software download thats just occured?
X
xyznicko
It's software.
Looks like they have fixed the Picture Quality, and I have heard that the operating temperature of the Skyplus has been lowered.
So you may hear the fan running more often than before.
Starburst
My V1 had been updated, the only thing different I can see is the model number change, obviously didn't suffer from the PQ problems:)
That being said still a comfort to know that it looks like they finally fixed an annoying problem which affected tens of thousands of users.
W
wattsj
What other new features are coming then ?
X
xyznicko
There's not a lot, from what I have seen looking at my sisters digibox there is;
1. A messages icon added to search/scan banner
2. There are new options for viewing in different aspect ratios, menus have changed to accomodate this.
3. You can select a second TV to be 4:3 while the main TV is widescreen.
D
Dalorp
It also switched off the RGB output for some reason. I had to go into menus and switch it back
X
xyznicko
Originally posted by bignairy
What is your operating system software number?
The number you have given is the box version isn't it?
The EPG and operating system numbers have not changed, the software model number has.
Speculation is that it is an update to the MPEG2 chip microcode.
mw3cdj
I have just checked my model number and it is 2.057A2 but i don't seem to have these new features , any idea why??
Thanks ,
Daran.
Starburst
Thanks ,
Daran.
At this time the other features mentioned have only been added to standard digiboxes with PACE models being first inline. I expect SKY have issued the SKY+ PQ fix as it's a critical issue and will update the OS with the other features perhaps when they have been field tested on the other boxes.
mw3cdj
Thanks mate,
Cant wait for
I'm always changing format from one room to another, and think this would be a handy feature.
Regards,
Daran.
mw3cdj
Anyone heard anymore of this ???
My second box (PANASONIC) has all the new features , but my sky+ doesn't .
Any news :lease:
Daran
manny
same with me, my second ( grundig ) box has the second tv aspect ratio selection but my + box doesn't. seems odd. actually, seems stupid.
