skype
Discussion in 'General Tech & Gadget Forums' started by squirrely, May 23, 2005.
  1. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    I have just downloaded skype but not installed it yet,does anybody here use it and if so what do you think of it?
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Pretty good chat client (for IM'ing), very fast for file transfers compared to Yahoo and MSN.
    In terms of telephony - I've not used it but a friend has and they've said nothing negative about it to me.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,520
    London
    +1,005
    The only negative is that you have to talk where your pc is i.e. your pc workstation (unless you have a laptop that is!) :)
  4. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    True Tej - but seen this ? www.neonode.com
    Shape of things to come :) Just a bit TOO dear at the moment.
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,520
    London
    +1,005
    Oooh that looks swish, how much does it cost?
  6. buzlightyear
    buzlightyear
    Oct 8, 2002
    946
    46
    London
    +116
    The father in law has been using Skype and the Firebox VOIP phone £30, does what it says on the tin, need to have a slight tinker with the sound setting within XP to get your normal sound out the Speaker and the voice to come out the phone. The most amusing thing is that randoms can ring you if you allow your name is in the address book. He had a lady ring him up and ask for a chat!!!!!
    Think i might set up a litte venture with some nice sounds ladies.. Read it here first.
  7. MarkR
    MarkR
    May 3, 2003
    1,849
    Somewhere in Kent
    +299
    We use Skype in the office and have bought Skype dect phones. This means all Skype to Skype calls are free and any other calls are charged at fraction of the normal UK rates.
    Another good thing about using Skype to call out is that it frees up the BT line.
    Would recommend this to anyone. (Who has Broadband). :cool:
  8. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Around £350 ish (inc. 1GB card) but Wifi type calling - useful abroad :)
  9. mrtbag
    mrtbag
    Dec 17, 2002
    3,509
    Anywhere I want
    +395
    Me and my brothe have been thinking about this recently. We both have laptops with necessary Headphone/mic sockets and broadband. Can anybody recommend any decent but cheap headsets?
  10. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    well i installed it ok but when i try a test call it sounds awful,there is a thud, thud,thud over everything i say, any ideas what could be causing this?
  11. MarkR
    MarkR
    May 3, 2003
    1,849
    Somewhere in Kent
    +299
    Try doing a calibration test in Messenger (if you have it) as this can be a good way to get the levels correct. This should also give an indication if your mic is at fault.
    You can also goto your Control panel and open Sounds and Audio Devices, once open locate the 'Voice' tab where you should be able to find a 'Test hardware' button. From here follow the wizard setup.
    Once you have Skype working properly the quality of the voice should be as clear without hiss or interference (Its almost as clear as CD quality).
    Good luck!! :cool:
  12. Drd
    Drd
    Jan 22, 2005
    1,817
    Approaching the doghouse at great speed
    +246
    My eldest went to Uni last September and only had access to a mobile phone,it was costing us a fortune.We switched to using Skype.Brilliant! Yes you've got to sit by the pc,but with a webcam and MSN messenger we can see each other too_One of the best bits of software on my pc!
  13. SanPedro
    SanPedro
    Jan 11, 2001
    4,505
    +505
    Just installed it last week to chat to family in Spain and Australia. All I can say is the sound quality is excellent. If you get it to load on PC start up you will always see whether your friends and family are online, and just one click away.
    A question for any techies out there...
    Can it be used with a suitably equipped 3G mobile. If you were to load it onto a pocket PC compatible device is there enough bandwidth to make it work? Is it even possible? I had this great idea that you could use it for making calls when abroad. When you make calls using SKYPE would it be classed as a data transfer? Am I right in thinking that with 3G phones you only pay for data transfer in downloading email or files from websites and that viewing web pages does not count as part of ddata transfer?
    If not then you could be making free calls whilst roaming abroad, or at the most only paying SKYPE's cheap call rates.
    Chris
  14. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
  15. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    It would depend on the operator what/how they charge but I am quite sure they include viewing of websites as data transfer since this also requires to download data (the content of the website that is).
    Skype would most certainly also be considered data transfer, just like streaming video or similar - and since it's two ways the operator may even charge you for sending of data.
    Beware, roaming is usually expensive.
  16. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,349
    83
    +193
    Look at the neonode site (URL above) - this is a phone using WiFi tech to call to landlines and mobiles (so in essence what you've described)
  17. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    I managed to sort out the sound quality problem i had but does anyone find there is a delay problem when talking to someone? iwas talking to someone who was not using headphones and i could hear myself coming through about 3 secs after i had started talking,i could get used to it but it does spoil the flow of a conversation.
  18. MarkR
    MarkR
    May 3, 2003
    1,849
    Somewhere in Kent
    +299
    I had that problem or at least my mate did, he replaced his mic with a slightly more expensive one and it has been fine.
    When your mate is talking to you, can he hear his own voice repeating? If he can't then this means your mates mic will need replacing and yours does not as his mic is picking up your voice through his speakers which of course is coming back to you :cool:
  19. CooperUK
    CooperUK
    Jun 30, 2003
    2,168
    Hampshire
    +289
    Skype is excellent, especially for use when online gaming with a mate. I manage to keep in voice contact with a couple of people on a more regular basis now too - if only more people I know would sign up and spend a tenner on a headphone set!
  20. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,004
    48
    Reading, Berkshire
    +54
    Are we seeing the same phone here? The neonode doesn't even have wifi, let alone the ability to make VOIP calls. I've wanted a neonode since it's initial spec burst onto the scene in 2001, and they have only recently (April) released plans to build the new n2 with wifi included. I think you may be getting confused, currently the n1m is just a bog standard GSM phone, albeit one with a rather nifty optical touchscreen and windows CE underlying OS.
    As it uses windows CE as the underlying OS, it WOULD be possible to use a skype type program to make VOIP calls via GPRS, quite how useful this would be is unclear (data costs loads!) Currently there IS a version of Skype for PocketPC, and using a device such as the i-mate jam in conjunction with a wifi SD card, this is probably the only way to get realistic portable VOIP for a while yet.
  21. captainH
    captainH
    Mar 17, 2004
    885
    43
    Bucks
    +239
    I found a 2-3 second delay on skype when using my laptop over wifi but I put this down to the fact that I have all the WEP encryption etc. enabled because when I use the desktop PC it's perfect.
    I ended up buying a a Siemens S645 and M45 USB adaptor and can now use skype via the DECT phone from anywhere in the house. It's quite a pricey solution but is excellent and thoroughly recommended if you use skpe a lot.
    If I'm working abroad I just get the missus to use skypeout to call my hotel. A huge saving over using my mobile or hotel phones. Call quality is generally perfect (unless I have left my security camera streaming over the broadband connection in which case she sounds like Norman Collier)
  22. dejongj
    dejongj
    Sep 11, 2003
    28,510
    Beautiful South
    +4,772
    A little tip for all your guys with sound quality problems...Check your QoS settings on your broadband router if you have any, make certain you give your VoIP services priority and a guaranteed slice of bandwidth when you use it...This should improve your sound quality immensely...That and spending more than a tenner on a headset ;-)
  23. jimbobaggins
    jimbobaggins
    Dec 29, 2002
    491
    Up North
    +18
    I use Skype for both chatting for free and also, through Skypeout, as a replacement for my BT phone, when phoning normal BT phones.
    Skypeout cost about 1.2p per minute at any time, anywhere in the UK.
    Mobiles are between 10 and 20p a minute depending on the time of day.
    The echo of your voice you are getting, is probably due to the sound coming from your receiving callers sound coming through their speakers as feedback. If they had a headset this would disappear.
    Skype is actually from the guys who developed Kazaa, so it works by P2P networking rather than typical VoIP, and it is clearer than a normal BT line due to the way the sound is encoded and decoded digitally. Also I have been trying out Skype on my wifi enabled PDA and it is not very good yet. Even when I am sat next to my wireless router, so I wouldn't think a public hotspot would be better (though I have not tested it).
  24. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Just to add that the sype out call costs are the same in the uk as many places in europe, I have family in Spain and fixed line or mobile costs are the same as phoning my mate round the corner.
  25. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,928
    2
    167
    Birmingham, UK
    +9,663
    Quality headset
  26. cluey
    cluey
    I am dealing with a propriatory VOIP system and am keen to see if I can use my pc spearker to ring but hear the call through my headset.
    Does anyone techie know how I might do this with my SoundMax Digital Audio pci card?
    Thanks!
  27. Hi/zuum
    Hi/zuum
    Oct 4, 2005
    3,841
    Nottingham
    +368
    Anyone here using Skype's video calls here? I've just started via my Isight/Imac to my sister's PC. It works a treat! Even making a landline call from skype works out cheaper & better quality than normal methods. Why pay for a landline if you're already paying for broadband?
  28. KeithO
    KeithO
    May 28, 2003
    1,432
    63
    Erding, Bavaria
    +214
    Yep. We use Skype at lot. Have family in UK, France and USA (we live in Germany) and the Skype video is excellent. I have a landline but only so I can get internet access...actual phone has been disconnected for over a year now
  29. SimP
    SimP
    Aug 18, 2005
    137
    +3
