Skype History Question
Discussion in 'Desktop & Laptop Computers Forum' started by juniper, Jan 18, 2008.
  1. juniper
    juniper
    Dec 30, 2003
    1,903
    48
    +60
    Hello, not posted in this forum before, so not sure if it is the right place or not, but I have a Skype question please. I have recently started using this, and wanted to know it allows you to delete your history of conversations anywhere? I've tried searching in Skype, but to no avail. Can anyone help me please? Thanks!
  2. waxdart
    waxdart
    Nov 19, 2007
    207
    +15
    The Skype FAQ says
    http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=310
    How do I delete my Chat history?
    You can delete your entire Chat history by going to Tools -> Options -> Privacy and clicking on "Clear History".
    This deletes all of your Chats. It is not possible to delete the history of just one Contact. (Note: These directions are for Skype version 1.2 and higher. This option is found under File -> Options in previous versions).
  3. juniper
    juniper
    Dec 30, 2003
    1,903
    48
    +60
    Many thanks for your help, and your prompt reply. It works too!:thumbsup:
