Question Skylake CPU Cooler
Discussion in 'PC Gaming & Rigs' started by Oishii, Apr 20, 2016.
  1. Oishii
    Oishii
    Apr 12, 2016
    7
    4
    UK
    Hello guys/girls,
    I am doing a mAtx build. I need help choosing a cpu cooler for the Core i7 6700k. I am not very up to date with the current gen pc hardwares as the last pc build I did was a long time ago. Core to quad ;)
    I was thinking of getting the Silverstone TD03-lite which cost £47 at Scan. Is this a good cooler?
    There are also 3 other 120mm AIO coolers +/- £60 (also on Scan) : Fractal Design KS T12, Silverstone TD03-E and the NZXT x31.
    For Air cooler I have read that Coolermaster Hyper 212 Evo and Cryorig H7 also are very good and both are around £27. The H7 is also compatible with the choice of my RAM.
    Hardware for my new build:
    CPU: Intel Core i7 6700k
    CPU cooler: Undecided
    Motherboard: Asus Maximus Viii Gene
    RAM: G.Skill Trident Z 16gb
    GPU: Reuse my current one.
    PSU: Reuse my current one.
    Storage: Samsung EVO 250 gb
    Case: Silverstone TJ08-E
    Thank you,
  2. Fxz123
    Fxz123
    Mar 23, 2015
    UK
    I would go with the Cryorig H7. I have heard a lot of good things about it.
  3. razy60
    razy60
    Jan 13, 2008
    1,146
    83
    Eastbourne
    +277
    If you have the space then a 240mm rad is the best option personally I've used the Corsair coolers, all have been excellent, Pc I just sold had the h100i gtx, currently I'm using a h80i v2 for the cpu(its a bit deeper than other rads) and a h55 for the gpu.
  4. messenger
    messenger
    Mar 28, 2006
    1,229
    Southend-on-Sea
    +191
    I use the Noctua NH-U14S U-Series CPU Cooler on my Skylake chip, you will need a midi size Tower Case to accomadate one but this cooler is very very quiet.
    Have fun choosing :smashin:
  5. subi
    subi
    Jun 29, 2014
    19
    4
    Agree ,Noctua winner :)
  6. mozza54
    mozza54
    Aug 25, 2010
    3,289
    Rotherham
    +429
    The H100i is a popular choice if youve got the room, the H80i is also decent. I had one cooling my old i7, worked really well but was too thick for my liking and looked rubbish in the case.
    On the lower end of the cost scale, the Evo 212 is excellent for the money and the Cooler Master Seidon 120v can be picked up for about £33, its a decent size so easy to fit in small cases (I had mine in an itx build) and performance is really good.
  7. Oishii
    Oishii
    Apr 12, 2016
    7
    4
    UK
    Thank you for the replies. Unfortunately I can't use dual rad AIO coolers as my case doesn't support it, 120mm is the max I can use. The Noctua CPU coolers have good cooling and low acoustics from reviews but the only problem with them is the colour of the fan. Who knew choosing a CPU cooler was this hard :)
  8. alphaomega16
    alphaomega16
    May 17, 2005
    13,587
    163
    Southend on sea
    +3,327
    You dont have to use the fan that comes with it and besides how often are you going to be looking at the inside of you case.
  9. Oishii
    Oishii
    Apr 12, 2016
    7
    4
    UK
    True.
  10. Oishii
    Oishii
    Apr 12, 2016
    7
    4
    UK
    I looked at the U14S. The only problem with it is that it makes my main PCI-E x16 slot unusuable.
  11. sykotik
    sykotik
    Sep 8, 2008
    6,834
    co. durham
    +2,145
  12. Oishii
    Oishii
    Apr 12, 2016
    7
    4
    UK
    Thank you for your inputs. I decided to go with a Scythe Kotetsu.
