SkyHD subscriber near me willing to assist ...
Discussion in 'Sky Digital TV Forum' started by chachi, Aug 26, 2006.
Thread Status:
Not open for further replies.
  1. chachi
    chachi
    Looking for a local SkyHD subscriber who might not mind popping over my way for a pint to help in a bit of testing.
    I've got a Humax HDCI2000 with a suitable cam and using my legit SkySD sub card can watch everything with no issues and a bit better PQ. Not sure whether I could do the same for SkyHD if I had a card, so need someone with a SkyHD enabled card (and their box's serial number) to come over to give it a quick test. Located in London SW16, just off the A23
    Anyone? :lease:
  2. drevil2nd
    drevil2nd
    Dec 2, 2005
    180
    +5
    think i can help you out here, i remember reading on satdudez, apparently the humax will play the audio but no picture on the hd channels.
  3. chachi
    chachi
    Hmm maybe I missed a thread then, I thought nobody tried using a 'proper SkyHD card' with the correct boxnumber, only with a 'SkySD' card lacking the channel permissions in theory, will investigate further :smashin:
  4. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Does that box do H.264? I'm not too far away.
  5. drevil2nd
    drevil2nd
    Dec 2, 2005
    180
    +5
    yes it does, works on the bbc.
    I believe the problem is the cam not the box.
    did you find the relevant threads?
  6. chachi
    chachi
    Yes ... the issue is the cam itself it seems :(
    Mods please close ...
Thread Status:
