I have a few issues since moving into a new flat complex last week.
There are three individual Sky wall sockets in the flat, and I have connected two up to my Sky HD box.
I'm missing a few channels (including Sky Premier Movies, and +1) and assume this is because although I have used two cables, the actual wall connections are both Horizontal Polarity connections and there isn't a Vertical Polarity connection. Is this correct? If so, is there any way I can change one of the connections to Vertical?
The other issue is Signal Strength/Signal Quality.
I usually get 0% Signal Strength (yes, Zero %), and around 50-60% quality from both connections. On occasion I lose the second connection.
I get break-up on all "UK TV" channels, but on nothing else.
Do I need to speak to the Management Company who look after the satellite in the building, or Sky, or not worry at all as I seem to get most channels ok?
Many thanks in advance for your replies,
Sam
Sam
