SkyHD likely to output both 720p and 1080i?
Discussion in 'Sky Digital TV Forum' started by richard plumb, Jul 13, 2005.
  1. richard plumb
    richard plumb
    Jan 27, 2002
    14,342
    Windsor
    +1,027
    Or is it likely that I'll be able to say 'no thanks, 1080i only' - and it'll convert internally?
    Just that it seems my TV doesn't accept 720p (philips 30pf9975), and its only a year - and £2k - old, so no chance of a new one just yet :(
  2. Tarbat
    Tarbat
    Oct 15, 2003
    2,512
    Easter Ross, Scotland
    +252
    Sky's HD website simply states that
    The use of "either" "or" would suggest that the Sky+HD box will convert between the two standards internally.
  3. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    The Sky HD box supports both 720/50p and 1080/50i - and HD broadcasters will be able to chose which standards they broadcast in. Sky couldn't really hope to proscribe a standard for all broadcasters to chose I guess.
    I would hope that Sky's receivers (like many sold in the US) will internally cross-convert between the two formats, allowing you to operate in one of three modes? :
    1. Output 720/50p in 720/50p and 1080/50i in 1080/50i
    2. Output permanently in 720/50p (de-interlacing and scaling 1080/50i to 720/50p)
    3. Output permanently in 1080/50i (interlacing and scaling 720/50p to 1080/50i)
    If you have a 720/50p native display it will be interesting to compare picture quality between 1. and 2. - to see if your Sky box or your display have the better de-interlacer and scaler when dealing with 1080/50i broadcasts... (Assuming Sky allow for a permanent output standard option)
    If the Sky box does a good job it might be worth running with a fixed output - especially if your display pops up annoying on-screen graphics or takes a while to lock-up on an input format change?
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,342
    Windsor
    +1,027
    I'll keep my fingers crossed then. Although its still crazy to have a 720p panel and have to feed it 1080i, its supposed to do a good job of downscaling (after the sky box might have upscaled it...)
    Although if it doesn't work, it means another TV and that'll have HDMI, so my PS3 is sorted :). And they are much cheaper than they used to be, so I could afford a 40".....(feels credit card slowly warming up)
