shreddieeddie
Established Member
Guys, I have read through lots of threads regarding this and getting a picture/sound looks to be fine but I just want to run something past you guys to see if its possible/I'm on the right track.
So...
Sky HD to a single other screen
SkyHD -> AMP -> Splitter (Octava 1x2 or similar) -> one to TV, other feed to Balun/cat5 to a second TV. This way what ever is output on the AMP HDMI feed will be shown on the second TV - Sky or PS3
Sky HD to multiple screens
Similar to above but this time going into the loft to a second 1x2 splitter which then feed off to two rooms - either HDMI cable if close or Balun/cat5 again.
Issues I can see - audio from the AMP over HDMI, in which case I would have to only have one source and put the splitter directly on the out of the HD box and then one feed to AMP and other to second route, can then manually plug in the PS3 if needed.
Are there any problems mixing the Octava and Balun units like plan to or do they just work where ever you put them?
Any other advice welcome...
TIA.
So...
TIA.
