TBird1
As is the case for many people my set up occasionaly suffers from lip-sync issues when watching Sky. This is because my audio is fed via my AV amp while the video is sent seperatly to my plasma (Pio 506xde). As I understand it (from reading many posts on the subject withn AV Forums) this is a common issue for many plasma owners.
AS far as I can see, the solution to this issue for the moment is to (a) purchase an amp that allows for audio delay or (b) purchase and audio delay box.
However - what do you think the chances are then that Sky's new HD box will likely have adjustments or a solution for sync problem? Especially considering the fact that nearly all SkyHD customers will be using LCD/Plasma/LCD/DLP Projector and many of these customers will have seperate audio amplification (and therefore I presume looking for improvemnt in audio syn) ??
Look forward to your comments,
TBird1
TBird1
