SkyHD and Phone Connection
MadMaelstrom
Just had my 2 boxes installed but as luck would have it they aint even close to a phone socket. I got round to thinking if you can run power over ethernet why cant i run a phone connection over it, or with a DECt adapter.
Is there such a thing or am I just being a bit over ambitious?
routy
chill out the sky engineers will install the phone cables its 50p per meter or something daft i wouldnt worry
trevor.dowle
Look at the wireless telephone extenders on the page:
http://www.maplin.co.uk/search.aspx...ia=EXTENSION CABLES & KITS&doy=9m12&worldid=7
I've got one fitted, and it works brill and completely out of sight.
borofoga
while adaptors such as this are switched on (they only work if they're switched on) are they not using electricity?
If so how much and will my electricity bill shoot through thr roof :confused:
Are these compatible with these http://www.devolo.co.uk/uk_EN/produkte/dLAN/mldlanhsstarterkit.html
trevor.dowle
Yes they are using power whilst in use, but I woould have thought it to be a negligable amount compared to other items that you probably leave on stand-by 24/7. e.g Sky box, Video/DVD, cordless telephone & etc.
Sorry can't help you with compatibilty with the power-grid LAN.
Podcast: Marantz SR7015 & NAD T 778 AVR + Mission LX2 MKII Speaker Reviews, AV & Film News and More
