planetf1
I have a samsung LCD/LEC tv UE46c6620. Connected to this is a new Amstrad Sky+ HD box (set to 1080i), and a Sony bluray BDP-S370
A couple of weeks ago we briefly connected a laptop over HDMI and immediately noticed part of the picture was chopped off. I quickly changed the screen image fit setting (from 16:9) to "screen fit" which appears to offer 1:1 pixel mapping on this set.
Since my other 2 primary sources are HD I assumed that it was appropriate to use this setting for all inputs, so that is what I'm using.
HOWEVER I've noticed that on some TV programs
- I occasionally see a green pattern (looks like data/noise) on extreme right/base of image - probably a pixel or two deep
- with "the gadget show" tonight
: the video used alternated (different shots) between filling the whole screen, and stopping about 0.5-1cm short in width
: the on screen graphics consistently filled the image, even when overlaying a chopped video
: the top 0.5cm or so was blank too
I can only assume these broadcasts are assumed to be watched using a safe area where those outlying pixels are lost -- surprising since this will involve some resampling and image degredation (I assume)
is this a sky phenomena?
Is this normal with all HD broadcast sources?
Do most ppl just run with default 16:9 settings except when viewing a more "pure" source - computer?
What about bluray?
Intrigued to understand more
nigel.
What about bluray?
nigel.
