Skybox with DVI output?
Discussion in 'Plasma TVs Forum' started by ncpl, Jan 30, 2003.
  1. ncpl
    ncpl
    Jan 21, 2003
    353
    Surrey
    the syncblaster thread has got me thinking.......
    Although I am about decided that my current Panny Skybox will get to the forthcoming Plasma via a JS RGB Scart to VGA converter, I am just struck with the question of how many sat decoder boxes have DVI outputs ?
    Would that fed to a suitable pdp give even better results than a RGB/VGA converter?
    Are any of you guys/gals using one to take DVI straight to a pdp?
    thanks
    Nick
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  3. ncpl
    ncpl
    Jan 21, 2003
    353
    Surrey
    OK......converter it is then...
    cheers
  4. sheggsl
    sheggsl
    Nov 16, 2000
    141
    UK
    +5
    I am sure that is entirely accurate Gordon, HDTV 1080i is interlaced and that is a supported DVI resolution. Have that going into my DILA projector and the projector recognises it as such. I beleive 480i is rumored not to be supported at the moment. However the DVI standards for HT are currently fluid and no one knows what will be supported in the future.
    I suppose the easy but not cheap solution will be to get an SDI modified Digibox if you can find one, "have been looking for a SKy+ one for awhile".....and then feed that signal into one of the soon to appear scalers HD Leeza or Assimilator which have an SDI input and DVI output.
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    1080i is not NTSC. It is an ATSC HiDef standard. My more accurate staement is that DVI doesn't support a low enough bandwidth for SD NTSC or PAL interlaced output.
    An sdi output SkyPlus box is the best solution anyway as you note. Unfortunetly they are MEGA expensive.£1000+
    Gordon
  6. robfitzp
    robfitzp
    Dec 12, 2002
    1,190
    38
    Bristol
    +20
    Not that I can remotely afford it at the moment but who modifies Sky boxes for SDI output?
    Rob.
  7. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  8. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Check out these guys as well.
    They're the ones responsible for the plasma screen reviewed here some time ago.
    The interesting part of the review is in the third paragraph where it states that the company can modify a digibox or DVD player to add an SDI output. :)
