Sky +
Discussion in 'Home Cinema Control & Remote Controls' started by chrisF, Jul 18, 2003.
  1. chrisF
    chrisF
    Jul 18, 2003
    5
    Poole, Dorset
    I am looking for a remote that will enable me to control all of my av equipment including sky+
    Does anyone know of a suitable device?
    The other equipment is:
    Denon amp
    Pioneer DVD
    Aiwa VCR
    Toshiba TV
  2. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    Whats your budget, there are lots of different all in one remotes available, from around £15 up to around £5000 !!
  3. ISHANTY
    ISHANTY
    Sep 13, 2002
    556
    3
    28
    UK
    +66
    The philips pronto is a good place to start it all depends on how much you are willing to spend plus it works well with my sky+
  4. chrisF
    chrisF
    Jul 18, 2003
    5
    Poole, Dorset
    Up to about £150
  5. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    In that case then the Philips Pronto
  6. ISHANTY
    ISHANTY
    Sep 13, 2002
    556
    3
    28
    UK
    +66
    i bought the pronto neo from R/Sfor 120 its good
  7. Sandman
    Sandman
    Nov 28, 2002
    3,608
    Glasgow
    +1,341
    IMHO the strandard pronto is better than the neo. Unless you demend more hard buttons, the original pronto is much more customisable than the neo. You should check out www.remotecentral.com this is the only web site you will need when discussing remote controls.
  8. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    If your looking for a site to buy remote controls from then i would recommend you try www.letsautomate.com. I got my pronto & docking station from them back last year, excellent service & price, next day delivery via UPS.
  9. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    For that sort of money its got to be a pronto, but beware they are highly addictive when making your own layout, i still havent used mine ive had it seven months :D
