Sky +
Discussion in 'Sky Digital TV Forum' started by locutuswolf359, Aug 16, 2005.
  1. locutuswolf359
    locutuswolf359
    Hi all, does anybody know if or how you can connect the sky + box to a pc. I would like to copy the video files to my hard drive to back up or Edit them. What type of file does Sky+ save recordings as? At the moment the only way i can get recordingins to my pc is by saving them to my Archos av400 PVR .
  2. johndon
    johndon
    Feb 3, 2002
    1,924
    48
    +88
    If you have a TV card in the PC, you can connect that to the Sky+ box either via coax or svideo - play a recording on the Sky+ box and record it on the PC.
    The files on the Sky+ HD are encrypted so you can't get them onto a PC directly.
    HTH
    John
    PS, Star Trek fan by any chance :)
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,149
    Argyll
    +2,214
    ...or alternatively use a DVD recorder. Much more user friendly especially if your Sky+ and PC are seperated!
  4. locutuswolf359
    locutuswolf359
    Thanks for the info guys, so there is no way to literally drag and drop files from the Sky+.
    John you guessed it i am indeed a star trek fan :thumbsup: . thought is was a good user name
