Sky
Discussion in 'Sky Digital TV Forum' started by Neil1996, Feb 23, 2005.
  1. Neil1996
    Neil1996
    Any help appreciated!
    Today my Sky pic has disappeared with the "No Satellite Signal is being Recieved" banner on screen on every channel.
    My question is that i can still get the TV guide up and my signal test shows strength/quality at 60/50% respectively(my normal readings)?
    Could my dish have moved enough to affect my pic but not enough to lose signal completely? or is something else possibly wrong. Have checked all connections round back of Tv/Sat box(dont see it could be box fault as wouldnt get tv guide).
    Also are my signal strength/quality readings typical, should they be better(neighbour has 75/60%), could they be improved by a better/bigger dish or new/better LNB? :confused:
  2. Duffers0
    Duffers0
    Try disconnecting mains lead. ait a few seconds and reconnect, box will reboot programmes should resume.
    Your signal quality is OK but could affected by current UK weather conditions, check no obstruction in front (line of site) of the dish.
    Good Luck!!
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    Check that your dish isn't iced up :cool:
