sky+
Discussion in 'Sky Digital TV Forum' started by bobby100, Nov 15, 2004.
  1. bobby100
    bobby100
    Going to order sky+ soon,
    Is their a box which i should say i want?
    i:e connections etc.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    There are only two models of SKY+ and while you could ask it's unlikely they will listen:) However it seems the PACE are now in short supply and you are likely to get the Amstrad model. Both have their plus and minus points as covered by other posts in these forums.
    There is a Thomson SKY+ (160) but is far more expensive than the standard models.
    They all have the same video and audio connections with the addition of two USB ports on the Thomson 160.
