sky+
Discussion in 'Desktop & Laptop Computers Forum' started by juls, Dec 8, 2003.
  1. juls
    juls
    Sep 11, 2003
    Penzance, Cornwall
    does any whon no what is the best way for me to captere sky+ and then send to my hs20 :confused:
  2. Kramer
    Kramer
    S-video to capture card (PB-TV100 from PC World) through Dscaler, via DVI to HS20 :)
  3. juls
    juls
    Sep 11, 2003
    Penzance, Cornwall
    hi there kramer thanks for that what about the PixelView Xcapture card or spending more on the SweetSpot card do you have any vews
    julian.
  4. vikingboy
    vikingboy
    May 31, 2003
    83
    berkshire, UK.
    the best way - easy :)
    SDI out of a SKY+ box into a H3d-ii.
    See www.irj-tech.com for details and screenshots.
    next best is RGB, then svideo and lastly composite into a capture card of choice (Sweetspot, Pinnacle etc)
  5. Kramer
    Kramer
    The Sweetspot isn't yet available (next week hopefully) but looks like the ideal solution for RGB capture from Sky etc. Can't wait to try it :)
    SDI from Sky+ only on version 1 boxes at present. Wasn't greatly impressed with the H3D - several problems from what I could see, not least of which was a pretty pronounced green push :( Not cheap either :eek:
    X-card - not had much chance to play with one yet.
    Hence, PB-TV100 (< £30) & Dscaler is probably the cheapest reasonable solution at present.
    Had problems with Pinnacles PCTV Rave card(s) - horizontal ripple occassionally which, try as I might, I could never cure.
    No such problems (so far) with a PB-TV100.
    :smoke:
