Sky+
Discussion in 'Sky Digital TV Forum' started by SteveRSF, Nov 10, 2003.
  1. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Hi guys, i just had sky+ fitted and as usuall they had done the job in about 5 mins!........so after they had left i fitted an optical cable between the sky+ box and my yamaha A1 for sound and an s-video cable for the pic but no pic come up,so i've left the scart cable in and suggestions?
    will i get a better pic from the s-video cable?,cos a plasma is next!:) :)
  2. gbmitie
    gbmitie
    Apr 25, 2001
    1,139
    49
    republic of ireland now
    +61
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    There is no setting in the picture menu for s-video.The Scart output will be for RGB(best) or PAL(composite-don't even consider it).S-video is only available from the s-video socket on the back.But using that means widescreen switching will not work.Whatever you have Sky+ connected to may be set for s-video,and with Scart you will not get an s-video picture
  4. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    in the audio menus there is an option to turn on the optical output.
  5. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    yeah thanks guys, i have the optical set on the sky box but only get some of the broadcasts in digital,as there are only a few!.....................as far as the s-video cable, am i picking it up right that i would be better to leave it as it is with the scart cable ? i only have a 32" crt
  6. obiwan
    obiwan
    Nov 22, 2002
    319
    Devon
    +5
    The guy who done mine was really helpful, he installed all the cables and set up every thing on av amp and checked it all worked, is this not the norm then!!
  7. SteveRSF
    SteveRSF
    Nov 10, 2003
    270
    Nah m8, i went to the hifi shop the day before to make sure i had all the new cables and when they were fitting they just said "aw you can just fit them when we've gone"
