Sky with widescreen question
Discussion in 'Sky Digital TV Forum' started by Weinberg, Dec 9, 2003.
  1. Weinberg
    Weinberg
    May 25, 2003
    102
    Sky was installed today. I have a widescreen panasonic TV, and a Thomson digibox. I'd like to know which setting is the best to get normal sized (ie non stretched) pictures. I've found that if I change the setting to 16:9, then widescreen signals are detected and my TV adjusts itself to show them properly. If it's on 4:3 this doesn't happen. If I have a widescreen, should I be using the 16:9 mode and leaving my tv on auto-adjust mode? What settings should I use to get a normal sized picture?
  2. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    I keep mine on the widescreen setting all the time. I think most channels cater for this now. When I had my 32" I used to have it on the automatic setting which I found a pain especially when it came to adverts as the screen kept adjusting. If you are watching a programme and it is strecthed just flick through the settings until you find the right one.
  3. Weinberg
    Weinberg
    May 25, 2003
    102
    When you say keep it in widescreen mode, do you mean 16:9 mode? I find "Panasonic Auto" (where the pic adjusts) to be fine, and in this mode it goes to widescreen if an actual widescreen signal is detected. 16:9 often looks squashed/stretched.
    So do I keep the sky box in 16:9 mode then?
  4. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    On mine it is called widescreen it doesn't say 16:9. Sorry cant be of more help.
  5. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    yes, keep the digibox set on widescreen/16:9.
