Sky + With TV Link
Discussion in 'Sky Digital TV Forum' started by toby, Jan 24, 2002.
  1. toby
    toby
    Had Sky + installed recently, what a great bit of kit !
    One question if anyone knows, I've got a tv link attached for a tv in another room, which works fine apart from the remote not working. I've tried both the new sky+ remote, and the old digibox remote, without any luck.
    Having called sky, they were a bit vague, but thought I might need a new tv link ??!! Anyone got any suggestions ??
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Check to see if the power is switched on to the TVlink.
    If it isn't then you will get a picture but the TVlink won't be avle to carry the IR signals back to SKY+.
    Services - 4 - 0 - 1 - Select
    RF OUTLETS
    Second Output Power Supply ..... ON
  3. toby
    toby
    Ok, tried what you say, and it works fine now.
    Thanks for that :)
