Sky+ with Multiroom
Discussion in 'Sky Digital TV Forum' started by adymcd, Jul 7, 2005.
  1. adymcd
    adymcd
    Jul 7, 2005
    16
    I currently have the standard sky digital box and would like to upgrade to sky+. If I purchase a box independently of Sky will it work fully? Also will I be able to use my current Sky box in another room or do sky have to activate this function?
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    You can do the Sky+ install yourself and then ring Sky to make the necessary upgrades to your Sky package. If you install a quad LNB and the necessary cabling, you could use your extra box but you'd need to get an additional card.
    John
  3. adymcd
    adymcd
    Jul 7, 2005
    16
    What are the required upgrades to my sky package in order that sky+ can be received?
  4. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    Depending on your current package, you may be entitled to Sky+ free or you may have to pay £10 per month. Either way, you'll to talk to Sky as they need to activate the '+' features of the box.
    John
  5. adymcd
    adymcd
    Jul 7, 2005
    16
    I have a full subscription at the minute so I think that I will get Sky+ free. With regards to the extra card for the multi room what do the normally charge? is this the £10 per month?
  6. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    If you have the full package then Sky+ will be free. A 'mirror' card for the multio room sub will be £10 per month.
    John
  7. adymcd
    adymcd
    Jul 7, 2005
    16
    Cheers John, Thanks for your help.
