Sky+ with:" loftbox "
Discussion in 'Sky Digital TV Forum' started by graham w, Mar 1, 2005.
  1. graham w
    graham w
    Anyone got details if a loftbox can be used with Sky+
  2. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Yes, but you'll need to run a second feed...
  3. graham w
    graham w
    Thanks,
    when i built the house i put 4 extra ct100 feeds in,is this ok for loftbox return feed?
    Also sky are coming tomorow so without tying you down too much can this work work as i havnt got the loftbox yet?
  4. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    That will work...
  5. Tarbat
    Tarbat
    Oct 15, 2003
    2,512
    Easter Ross, Scotland
    +251
    I think you'll need a Loftbox Expander and Diplexer as well
    From http://www.tvlink.co.uk/expander.htm and http://www.tvlink.co.uk/diplexer.htm
  6. graham w
    graham w
    Thanks for the posts.
    I have just had the extra sky+ fitted,i helped the guy fit it.
    I pulled the cables through the loft from dish to sky box and left a loop long enough to cut into when i get the loftbox.
    Am i right in saying i need to cut into one of these cables and connect it to the loftbox?
    Also the other cable that goes to the sky box remains ,doing this does it removes the need for an expander?I also fed a ct100 fron the sky box so this can be the return feed.
  7. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    You only need a 'Loftbox' if you also want DAB, FM and CCTV into the living room along with the Sky... For Sky+ you simply need two feeds from the dish to the digibox and a single return feed to the loft amp... What exactly do you want (a) in the living room and (b) at your other outlets..?
  8. graham w
    graham w
    Cheers Simon,
    I have 2 sky+ boxes in seperate rooms on the ground floor,
    one box feeds the main bedroom via a wireless sender which is fine.
    In the other bedrooms and kitchen i would like digital tv,sky,analogue and i have a security camera on uhf, with the second sky receiver supplying the signal for sky+.
    As previous the 2 feeds pass thro the loft to the sky recever i want to tap into, and a ct100 coming back.
    The rest of the cables are in the loft(feeds to the other rooms in rg59) and also the coax for the camera.
    If this is the case do i link one cable from the dish to the loft box ,and leave the other coax from the dish alone?
    Also the outputs from the loftbox are run as a single cable with 4 signals going down it,how does the tv receive all this info from 1 rf lead?
  9. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
  10. graham w
    graham w
    Thanks again,
    i seen this link and wondered where the missing cable went from sky+ dish.
    So you only cut into one which also gives me another spare feed to the sky box back to the loft.Does the tv have to be tuned in to accept the new signals?
  11. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    That's correct (no harm having a spare cable!!!)... Sky+ RF2 output is on CH68 by default, just avoid this and the other analogue TV channels and you'll be fine, then simply retune all your TV's...
  12. graham w
    graham w
    Thanks for that mate!
    Now to find a dealer to supply it all ,now i know how it works.
    Seems a clever bit of kit!
