Sky + wish list
Discussion in 'Sky Digital TV Forum' started by Blu Ray, Jun 22, 2004.
  1. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    There are 2 things that I really wish Sky would add to the Sky + box:
    :lease:
    1) Delete confirmation. How many times have you pressed that yellow button and said S**T, wrong one! :mad:
    2) PDC. They have it on VCR's why do I have to watch up to 5 mins of rubbish before my program starts, and sometimes miss the end!
  2. Lawe
    Lawe
    Dec 30, 2003
    123
    19
    Hampshire
    Well I agree with option 1. I to have been "trigger" happy with the yellow button!
    As for other wishes, a 30 second fast forward button to get past the adverts
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Blu Ray - I've done this too! Annoying, isn't it?!
    My solution is to put a keep on ALL your recordings as soon as you've done them. This way, you do get a 'delete confirmation'.
    Hope this helps!
    A Dork
  4. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,614
    48
    Lancashire
    +55
    Any + user not done it? The finger lingers just a fraction of a second too long then.......Doh
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,219
    +2,231
    Well as a convert from TiVo I would like.........
    Searching by programme name as you enter it
    Longer scedules
    Delete confirmation
    One button touch to get to Sky+ Planner
  6. LDJ
    LDJ
    Jun 18, 2003
    605
    +27
    How about:
    - Series links that dont just vanish!
    - Proper detail about why the box failed to make a recording you told it to
    - More detail about why a program failed recording half way through
    - a box that doesn't crash
    - series links for all the programs
    - Being able to use the EPG while a program is paused
    - facilities to alter the compression (to save disk space if needed)
    - control of what is deleted and when, not just what/when the box feels like it
  7. dUnKle
    dUnKle
    Jan 1, 2001
    15,219
    +2,231
    blimey
    I have only had it 24hrs - is it that bad ? will it get better ?
  8. LDJ
    LDJ
    Jun 18, 2003
    605
    +27
    it depends really. i read all the discussions about the million problems with Sky+ and assumed that if i didn't change the hard drive i'd escape the majority of them. i haven't touched the innards of the box and its still buggy as hell. the software really is lacking, even though the hardware is quite good.
    what worries me most is if sky try to fix the problems, because every time they try to fix something they end up making it worse!
  9. dUnKle
    dUnKle
    Jan 1, 2001
    15,219
    +2,231
    So do they update it then?
    With all there money surely they could just buy the TiVO software and combine them to make th best of both worlds
  10. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    They do 'over air' updates fairly often. One recent one was to allow recordings of two things at the same time.
  11. IainC
    IainC
    I'd quite like them to have a network port in the back of the box so you could archive off programmes to a PC, even if you couldn't watch them on a PC so that you had to copy them back to the Sky+ box to watch them it would save having to delete stuff all the time.
  12. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,533
    38
    Nottinghamshire
    +22
    What would be nice is if I could pick a set/group of programmes to be replayed one after the other continuously so I can burn them to my dvd recorder without having to play/record 1 at a time!!
    Now hopefully someone will post how this can be done and make me look daft!!
    Cheers..Andrew
    PS For all the bugs/problems (we had to have 4 machines on original installation to get a working one!!) I still think it's a bloody great piece of kit:)
  13. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    721
    43
    +165
    Prepare to look daft...
    Go into Sky+ planner.
    Highlight the programme you wish to record.
    Hit the 'Copy' button (designated on one of the fastext colours).
    Repeat the above for each programme you want to put in the sequence.
    When you have completed your list, highlight any one of the programmes marked for copy, then hit 'Select'.
    Those items you've marked for copy will now play in a line.
    Works a treat.
    Note hitting any buttons on the SKY remote, whilst your programmes are playing, causes the playing of the whole sequence to stop.
    Oh, and by the way,
    :rtfm:
  14. fulllupo
    fulllupo
    Jan 25, 2004
    271
    Cambridge
    +44
    Its annoying when u pause live tv/playing a few minutes behind real time, and u accidently switch channels and lose where you were, Done that the other day and missed the middle of the film. Doh!
  15. andrewmellor
    andrewmellor
    Dec 17, 2002
    1,533
    38
    Nottinghamshire
    +22
    Hi Lost Cause,
    Many thanks for that...we were trying to find the manual the other weekend but as all things that are put away under the stairs, it had mysteriously dissapeared :(
    I'd hoped that it would have been possible and posted the above with tongue in cheek.
    Cheers for taking the time to reply,
    Andrew
    PS Took me a few minutes to suss the RTFM meaning.....Ha Ha:)
  16. lonestar
    lonestar
    Jul 26, 2001
    182
    maghera, n.ireland
    +4
    for me a killer app would be the ability to edit any recorded programs, to remove unwanted rubbish from the recording, ie ads or any padding.
  17. NicolasB
    NicolasB
    Oct 3, 2002
    6,450
    Emily's Shop
    +898
    I can think of countless improvements to Sky+ but the two things about it that irritate me the most (on the occasions when it is actually working to specification) are:
    1) The inability to switch subtitles on and off with a simple button press.
    2) The way the +/- channel buttons zap you out of a live-pause playback without asking you whether you really mean it, and lose the buffer.
  18. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    let's hope Pace or Sky read these forums then!
