SKY+ - wiring from Quad LNB
Discussion in 'Sky Digital TV Forum' started by wanblue, May 19, 2003.
  1. wanblue
    wanblue
    I'm having SKY+ installed soon.
    The original SKY installation was a pain as I live in an old building and the co-ax from the LNB to the box needs to be run through several cavaties.
    Does SKY+ need two coax wires, or does it just re-use the exisiting one??
    Thanks in Advance
    Ian
  2. Fairzo
    Fairzo
    Apr 8, 2002
    107
    16
    It will need two, to the two tuners. When I had the installation done the old cable was abandoned and a new double cable routed through.
  3. wanblue
    wanblue
    How much effort will sky go to.
    It would need to go throught the loft (easy), behind two cavity walls (external wall 2 ft thick), under floorboards and then through conduit.
    Will they take this amount of work on for nothing??
    TIA
  4. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    The don't do two runs, only an additional run.
    Did they install the first one? Even if they didn't you could say that they did, and they should do it again. ;)
    StooMonster
