Sky Wireless Connector to non sky router
Discussion in 'Sky Digital TV Forum' started by henry1234, Sep 10, 2012.
  1. henry1234
    henry1234
    Nov 15, 2002
    341
    Worcestershire
    +8
    Hello,
    How do I access the wireless connector to set it up so it will auto connect to a new NON SKY router (technicolour TG582N)?
    My sky subscription & broadband is ending in a few days and I have taken out broadband with another ISP and bought a new router. I assume I will no longer be able to use the sky router (I also need a router to work with VOIP).
    My sky wireless connector auto connects to my sky router at the moment. It works well when plugged into a Humax HD-R and also a Popcorn Hour C-300 as well as the sky box.
    I was hoping to re-use the sky wireless connector as I was one of the mugs who paid £60 for it.
  2. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,169
    Should work fine, but you'll probably need to go into the digibox settings and enter network name and wifi key etc.
  3. henry1234
    henry1234
    Nov 15, 2002
    341
    Worcestershire
    +8
    Good to know it can be made to work. Thank you.
    Is there any way to change the settings without using the digibox (I didn't know I could do that)?
    The reason I ask is that I was going to sell my HD box when subscription ends but I wanted to use the sky wireless connector to connect my Humax FoxSat HD-R to access on demand.
    I can set it before I sell the digibox but if I change the router or it's key or SSID in the future it will render the sky connector it useless if I don't learn how to change it without the digibox.
  4. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Very true. Still, you can get a generic bridge for under £20...........
  5. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,169
    Doubt it, it was specially designed for just that...
    You could check your router to see the devices connected to the network and check to see if it has a web interface, but I wouldn't hold your breath...
  6. henry1234
    henry1234
    Nov 15, 2002
    341
    Worcestershire
    +8
    Thanks for the replies.
    So it's tied into to sky really (and it cost me £60)!!!! Worst buy ever.
    I may sell it with the sky box and hope that I can raise some extra £££'s to go towards buying a cheaper generic bridge that I can use with my other equipment.
  7. nick7500
    nick7500
    Oct 10, 2012
    4
    Hi sorry to hi jack your thread, I have a sky wireless connector and it wont conect to my bt home hub 3 any ideas thanx.
  8. niall campbell
    niall campbell
    Nov 16, 2007
    1,048
    48
    +66
    Have you switched on wireless on router , switched on Mac addresses only in router, put in right code , tried lowering security measures on router
  9. logiciel
    logiciel
    Feb 2, 2008
    53,104
    UK
    +5,759
    Posters don't own threads - all OT contributions are welcome.
  10. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Have you followed the instructions that came with it?
    (Ignore references to MAC addresses and Security Settings)
  11. nick7500
    nick7500
    Oct 10, 2012
    4
    Hi Guys
    I have a sky wireless connector and it wont conect to my bt home hub 3, have read all instructions etc any ideas will I have to change router settings and how to I do that ? thanx.
  12. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    You're now in trouble with the mods for creating/adding to, two, identical, threads!
    If you follow the instructions there should be no reason to change any router settings.
  13. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    Just a quick thought, have you activated Anytime+ on your Sky account?
  14. nick7500
    nick7500
    Oct 10, 2012
    4
    Yes as I said in my post to you was using this before.
  15. niall campbell
    niall campbell
    Nov 16, 2007
    1,048
    48
    +66
    Why is that ??
  16. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    The network key is case sensitive and most homehubs use numbers and lower case letters. Don't forget you need to press multiple times to get a number and lower case letters.
