sky + which is ??
Discussion in 'Sky Digital TV Forum' started by jonthebarber, Jan 8, 2004.
  1. jonthebarber
    jonthebarber
    sky + box has stared to freeze on playback , as its nearly 2 years old i will replace the hard-drive . i have looked around on this forum for whats best , i don`t need massive storage , just one that is quiet and relable ! what do you all surgest and wheres the best deal ????????
    jon .
  2. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,578
    48
    Lancashire
    +49
    I cant give it my aproval yet (it's only just arrived) consensous seems to be - no more than 120 Gb, Maxtor or Samsung, definatly not Seagate, 5400rpm preferable (not imperative). I struggled to find anyone selling these 'slower' drives, but bought the Samsung from savastore.com. £85 inc delivery - not the cheapest advertised, but the only people stocking this spec drive. You will probably get an 80Gb drive much cheaper/easyer. Someone else may know more but dont normal sky boxes freeze - so it my not be your hard drive, I'd find out more before buying another drive for a broken box.
  3. jonthebarber
    jonthebarber
    cheers for that . the other sky + box (upstairs) did it twice and was replaced under warranty the bloke said "harddrive" and changed the box ! so i am working on that fact .
  4. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    I upgraded mine with a Maxtor 120GB 7200RPM fluid drive bearing drive (maybe most HDDs are FDB these days I don't know). The case runs cool, less noise than the old HDD and all in all very happy. These drives can be picked up for about £70.
  5. jonthebarber
    jonthebarber
    top bloke !
  6. bobbles
    bobbles
    personally I would go for a 80Gb drive
    An awful lot of people have experienced many faults, in particular the 17min bug, with 120Gb drives.
  7. jonthebarber
    jonthebarber
    mmmmmmmmmm spilt choice ! anybody else ????
  8. jonthebarber
    jonthebarber
  9. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,578
    48
    Lancashire
    +49
    I've just posted about my upgrade, I'm impressed with the Samsung drive runs cool & quiet i think its a sp1203n.
  10. jonthebarber
    jonthebarber
    cheers for that , where did you get it from ?
  11. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,578
    48
    Lancashire
    +49
    Savastore.com I ordered a 5400 rpm drive, but when it came it was a 7200rpm disk, however prompt delivery & well packed. Rather than send it back I thought I'd try it, it seems fine. I think if you shop around you may find cheaper. I paid £85 inc post, but I thought I was getting a different drive. It seems they're all 7200rpm now. No one seems to stock the slower ones.
    Now, having done it, I'd be looking for the best price on the faster drive - 120gb are available from about £65. However some people whove fitted the Maxtor (often the cheap drives) have noticed they can be hot (the standard one I removed was red hot) My Samsung isn't & I don't think anyones posted saying theirs is. I'd certainly pay a bit more for the Samsung over a Maxtor for peace of mind. Having said that, others have no temperate issues with their Maxtor.
    If your confident the disk is faulty it's an easy & valuable upgrade IMO.
