Sky+ - when using Optical cable
Discussion in 'AV Receivers & Amplifiers' started by stevecc, May 23, 2005.
  1. stevecc
    stevecc
    May 16, 2005
    23
    Hi All,
    I wonder if someone can help me....
    I am having Sky + installed on Wednesday, and plan to connect it to my Amp using an Optical cable.....
    At the mo, my TV is connected to my Amp directly, and this is how I get audio from my current Sky box through my Amp (Sky is connected to my TV via SCART)
    If I remove these audio cables that link my TV to my Amp, will the Amp still transmit audio from Sky+/Optical set up, even when a Sky program is not being transmitted in Digital, or will I need to leave the audio cables that link my TV to the Amp in place aswell?
    Any experience with this will be appreciated!
  2. adam.philpott
    adam.philpott
    hello mate, if you connect sky to your amp via optical lead then you will transmit all audio via this lead, enjoy your sky, its really worth the money...
    regards adam :thumbsup:
  3. stevecc
    stevecc
    May 16, 2005
    23
    Thanks Adam!
    I was worried it would only transmit digital signals!
    I cant wait to get it installed!!!
  4. adam.philpott
    adam.philpott
    the thing is mate that all sky programs are in digital sound,,, not only the ones in 5.1, so all your bbc and sky1 etc will come out in better quality than befor, you just keep your amp on the same input setting regardless of the program.... enjoy
    adam. :smashin:
  5. paulryan
    paulryan
    Sep 2, 2002
    47
    Kent
    I had the same thoughts, i ended up contacting yamaha who were very helpful.
    Essentially the digital and analog audio circuitry is separate so the digital audio out from the amp can only output all the digital audios inputted
    same goes for the analogue audio out.
