sky+..... whats it got???????
Regards the optical out on the Sky+ box , my amp has one optical input and that is used just now by my X-box. Anyone know of an adaptor or box that can share optical inputs if you know what i mean?
Panic
I can't think where, but I've just seen something about optical splitters - possibly a link from a posting to somewhere like cable universe. maybe even maplins. Seek & you shall find! I don't know if they're much good.
You can buy a little black plastic thing that has one optical connection on one end and two optical connections on the other end.
You can use it to split one signal or join 2 signals but one of the two signals must be switched off at any one time.
Panic
This should do what you want:
www.keene.co.uk
For Toslink connections [BTZ1T] £29.99
B-TECH THREE TO ONE OPTICAL SWITCHER
Expand your optical inputs/outputs with these
switchable selectors. They allow any three optical
devices to be connected to the input or output
of a fourth, The simple rotary selector eliminates
the need for continuous plugging/unplugging of
your equipment.
Mark.
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
