Sky + (what format?)
Discussion in 'Sky Digital TV Forum' started by graham w, Feb 24, 2005.
  1. graham w
    graham w
    Does anyone know what format sky+ records in on the hard drive?
    Reason being i wanted to add some video files to the hd via the computer and try to view them.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    The Sky+ box uses the standard filing system as used in PC's, but all the files are encrypted. The box won't recognise any files you add.
  3. Roger G Cam
    Roger G Cam
    My simplistic understanding is that the Sky+ records the incoming signal - but does not decode it into any sort of video. It only decodes it when you watch it. Hence the picture is as good recorded as it is live - minus the red dot.
    So the box has two tuners - to receive the incoming signal - but only one decoder.
    You need to copy the recording somewhere else - perhaps to a DVDR with a HD - to edit/manage it in someway.
    Roger
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,281
    Manchester
    +763
    Yes it will record an encrypted (demultiplexed) MPEG stream
    Chris Muriel, Manchester.
