Sky+ Warranty
Discussion in 'Sky Digital TV Forum' started by thejudge, May 17, 2005.
  1. thejudge
    thejudge
    Oct 28, 2002
    189
    19
    Will my Sky+ warranty cover my remote control? It has recently started to act very strangely. At least 3 times a day it stops responding completely and i have to remove the back cover and take the batteries out ( Fresh Duracells) then place then batteries back into the remote control. This messes with my TV set up as it for some reason no longer seems to retail its code even though the batteries are only out for 10 secs.
    Very Strange! :eek:
  2. Astaroth
    Astaroth
    Jun 22, 2004
    2,258
    63
    London
    +101
    The standard 12 month warrenty would also cover the remote control. If you are talking about an extended warrenty then you need to read the T&Cs of your contract.
    The problem with remotes is that it is very easy to say that the remote has been dropped or it is natural wear and tear and not a manufacturing fault which is the only part which is covered by a manufactures warrenty
    I know when I used to sell Sky Care - their old extended warrenty package - the remote was something that was forever switching between being and not being covered.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Do you have a plasma screen ?
  4. Bluevanman
    Bluevanman
    Try using batteries other than Duracell. Some people say that the Duracells are too strong for the remote. Put in normal life batteries, they should last for around 12 months.
  5. JayCee
    JayCee
    Jan 20, 2004
    20,054
    Lanarkshire
    +1,912
    How do you work that one out :rolleyes:
    A remote control just like any other piece of battery-operated equipment will take as much current as it needs therefore if you use higher capacity batteries such as alkalines or Duracells they will last longer :lesson:
  6. thfccambs
    thfccambs
    Jul 17, 2002
    18,958
    White Hart Lane
    +5,011
  7. JayCee
    JayCee
    Jan 20, 2004
    20,054
    Lanarkshire
    +1,912
  8. thejudge
    thejudge
    Oct 28, 2002
    189
    19
    I don't just a 28" Widescreen CRT
  9. thejudge
    thejudge
    Oct 28, 2002
    189
    19
    I'll try different batteries and see what happens.
