Sky Volume
Discussion in 'Plasma TVs Forum' started by NorthST, Aug 8, 2005.
  1. NorthST
    NorthST
    Hi people, hope you all had a good weekend.
    Ok, I have the Pio 435XDE all rigged up. Everythings good apart from my Sky remote won't adjust the volume!
    Any ideas??
    Cheers in advance
  2. NorthST
    NorthST
    Don't lose me behind peeps!!
  3. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    186
    If you follow the on screen help for the digibox, you should end up at a page of manufacturers codes and details on how to enter them. Have you tried this and found the codes don't work? If so I'm sure there will be many 435XDE owners that have the right one.
    P.S Most people check back a few pages on threads so no need to *bump* too often :lesson:
  4. ikon66
    ikon66
    Mar 22, 2005
    449
    Tyne & Wear
    +5
    does the channel work?
    I used 0194 hope this helps :smashin:
  5. NorthST
    NorthST
    Yes the channel works. How do I get to this part of the setup menu?
  6. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    check out www.digiboxes.net
    they have a great guide on entering new remote codes onto the sky handset
    Dal
  7. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    I hope you don't think I'm being condescending but you have actually got the speakers that go with the XDE and not just a surround system haven't you ?.It seems very strange that the channel button works but the volume doesn't.
  8. NorthST
    NorthST
    Excellent! Well I never knew I could do that! My third try, code 451 has worked a treat.
    Many thanks
    :smashin:
