Sky volume control with Denon 2805
Discussion in 'AV Receivers & Amplifiers' started by t0by, Feb 27, 2005.
Tags:
  1. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    Can I control the Sky volume on my 2805 using the Sky remote? If so, what's the code, please?
  2. rondun
    rondun
    I assume you mean denon remote! - try 0883, 0874 or 1202
  3. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    Maybe I am getting mixed up here, but I did mean using the Sky remote. I have Sky into my 2805 via a JS RGB>YUV. I am using the Sky RC to change Sky channels and I wanted to use the same remote to change Sky volume via the 2805. Am I barking up the wrong tree? Should be using the Denon remote to change the Sky channels?
    Ta
  4. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    SKY only have preset codes for the remotes to control TV volumes no amp volumes.
    You can enter preset codes on the denon remote to control the SKY box but not SKY+.
    Other wise you will need Sky remote to select channels then amp remote to set your volume.
  5. rondun
    rondun
    Sorry, I misunderstood what you meant.
    The numbers I gave you were to try on the denon remote to control Sky
  6. PDM
    PDM
    I have configured BOTH remotes to control the volume on my 3805 i.e. Denon remote (as posted by Rondun above) and Sky Remote (via the following procedure : http://www.hummer.co.uk/remote-setup.htm)
  7. brendank
    brendank
    Dec 13, 2003
    684
    drogheda, co louth,ireland
    +6
    this will only work with sky plus box i believe :(
    if anyone knows differently please post
  8. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    Thanks for your help, guys. Since I only have normal Sky (not Sky+) I will look to set up the Denon remote and try to dump the Sky one...
  9. brendank
    brendank
    Dec 13, 2003
    684
    +6
  10. PDM
    PDM
    Hmmm... Had thought this works for all Sky Remotes (from a particular model number onwards).
