I've got an Hitachi 42PMA400E plasma screen and a new Sky+ box and I am waiting delivery of a Denon DVD2900 & AVR3803. The Sky+ box has an RGB scart output and S video (forget composite). The AVR has 2 component inputs and 1 S video. I'll be using one component input from the DVD (essential for progressive scan) but I don't think I can use the second for Sky+ without some expensive transcoder. The AVR has a built in upconverter to provide component output from S video (and composite). Does anyone know what will give me the best picture quality?: A method using the RGB scart in some way to convert to component? or Use an S video connector between the two and rely on a decent conversion from the AVR? The audio side is no problem with an optical cable connection to give me Dolby 5.1. I'm sure a lot of people have the same problem. Any help and advice would be gratefully received.
dont have a 3803 myself yet. but it will only give you s-video quailty through the component output. so i think the answer is a rgb to yuv converter( john sim for best results) i use one into my iscan ultra. no cheap way around it
Sorry I've been a while getting back. Thanks for the advice. The John Sim converter looks the best. There is a cheaper converter from Keene Electronics for £89.99 which may do the trick but I suppose it's not worth cutting corners when the rest of the system is up together. Thanks again.
