Sky+ via communal satellite dish. Have 3 SAT connections
Discussion in 'Sky Digital TV Forum' started by neilrufc, Sep 24, 2005.
  1. neilrufc
    neilrufc
    Can i connect SKY+ via a communal satellite dish. I have been told that Sky+ needs 2 connections or something. I have 3 white points in my apartment.
    1 in the living room,
    1 in the 1st bedroom,
    1 in the 2nd bedroom.
    Th white points have 3 connection. They are
    TV
    SAT
    FM
    Could i make Sky+ work by using 2 SAT connections?
    Neil
  2. JayCee
    JayCee
    Jan 20, 2004
    20,078
    Lanarkshire
    +1,912
    No, another lead has to run from the LNB on the dish to the Sky+ digibox.
  3. neilrufc
    neilrufc
    Thanks for your reply man
    I thought the LNB just allowed 2 different connections to the Sky+ Box. I have 3 SAT connection thoughout my place that allow me for example - to watch 3 different sky in 3 different rooms via 3 different boxes. I would have thought by connecting say the SAT connection in the living room to 1st connection on the sky+ box, then the SAT in the bedroom to the 2nd connection on sky+ box this would give me a complete working sky+
    What do you think about this??
    thanks again
  4. JayCee
    JayCee
    Jan 20, 2004
    20,078
    Lanarkshire
    +1,912
    Are you absolutely sure about that?
    Are they not just 3 outlets to enable you to have your sky digibox in any room?
  5. hog
    hog
    Jan 15, 2005
    380
    28
    +36
    hi
    if you have 3 of the triple sockets like you say , you just need to run a longer lead from the nearest one to the sky plus box.
  6. Ridcully
    Ridcully
    Feb 16, 2002
    330
    28
    +29
    The longer lead idea should work as this is what I have done on mine. I suspect the way your flat is set up is as follows.
    All four LNB feed going to a digital mux, TV and FM also mixed in with this. Then 3 feeds per flat taken off the mux, 1 for each room. Therefore each feed should be able to provide TV, FM and any sky feed irrespective of the others
  7. neilrufc
    neilrufc
    Can you watch say 3 sky boxes on different channels at the same time via your SAT feeds?
  8. Ridcully
    Ridcully
    Feb 16, 2002
    330
    28
    +29
    Yes. The mux has all four LNB feeds. So all it does is send the correct on down the cable depending on waht is asked for by the Sky box.
    With regards to your PM about the sky+, yes it should work
  9. neilrufc
    neilrufc
    Do i need special cable for this or will coax cable be cool?
    thanks
